C# vs Python
C# vs Python
Postby ReversE_3ngineeR » 20 Apr 2016, 00:00
Recently got Mk 2/4 to automate some measurements for research. In undergrad I worked as research assistant and made some code in C# for a grad student to make a Mk 2/4 do some scanning similar to what I'll be doing. I've been .NET my whole programming career so I was thrilled to see C# API, but I'm really getting into and loving Python lately. Anyone know pros/cons to interfacing with Python? For example, not knowing position or something when there is a function for it in the C# API? Python's ease of use and cross-platform compatibility make it look like a real winner to me.
ReversE_3ngineeR
Re: C# vs Python
Postby pform » 13 Jun 2016, 20:37
Hi,
I too would be interested in using python.
pform
pform
Re: C# vs Python
Postby Support » 17 Jun 2016, 09:50
The case here is, if Python is able to use API Windows files...
Re: C# vs Python
Postby NeoTech » 26 Aug 2016, 19:24
you should be able to use ctypes in Python handling the API if its in solid DLL.
Code: Select all
import ctypes
# Load DLL into memory.
hllDll = ctypes.WinDLL ("c:\\PComm\\ehlapi32.dll")
# Set up prototype and parameters for the desired function call.
# HLLAPI
hllApiProto = ctypes.WINFUNCTYPE (
    ctypes.c_int,      # Return type.
    ctypes.c_void_p,   # Parameters 1 ...
    ctypes.c_void_p,
    ctypes.c_void_p,
    ctypes.c_void_p)   # ... thru 4.
hllApiParams = (1, "p1", 0), (1, "p2", 0), (1, "p3",0), (1, "p4",0),
# Actually map the call ("HLLAPI(...)") to a Python name.
hllApi = hllApiProto (("HLLAPI", hllDll), hllApiParams)
# This is how you can actually call the DLL function.
# Set up the variables and call the Python name with them.
p1 = ctypes.c_int (1)
p2 = ctypes.c_char_p (sessionVar)
p3 = ctypes.c_int (1)
p4 = ctypes.c_int (0)
hllApi (ctypes.byref (p1), p2, ctypes.byref (p3), ctypes.byref (p4))
NeoTech
Return to API
