diy MK1 no response
diy MK1 no response
Postby soslhg » 30 Nov 2016, 15:54
According to this article http://planet-cnc.com/diy/
I use this schematic http://planet-cnc.com/wp-content/upload ... Silviu.pdf
I use this bootloader http://planet-cnc.com/wp-content/upload ... 100111.zip
There are four documents, I have tried each, after downloading boot, when the usb connected to the computer, there is no response.
This is not a driver issue, because the computer did not sound when I connect usb. And there is no change in the device manager.
After downloading the boot, I have tried [Connect Jog8 (RB4) to Vcc and Connect to USB].
Now,I do not know what to do...
soslhg
Re: diy MK1 no response
Postby Support » 01 Dec 2016, 12:34
Was boot-loader successfully uploaded? You did not have any problem? Your PCB is correct and all elements are correct and soldered properly?
Try this USB driver with your latest sw version:
http://old.planet-cnc.com/files/CNCUSBC ... Driver.zip
Postby soslhg » 02 Dec 2016, 02:32
Support wrote:Was boot-loader successfully uploaded? You did not have any problem? Your PCB is correct and all elements are correct and soldered properly?
uploaded no problem,only verify hava an error about eeprom。
I try to replace another new picf18f4550,but still eeprom error。
It's not driven's problem,because computer no sound when link usb cable.
the usb is no enum.
soslhg
