DIY did not recognized by the software
Postby naser » 15 Sep 2015, 11:00
Dear Sir
My name is Naser
I made DIY board
When I programmed the PIC with the file ( CNCUSB_Bootloader-20100111_fixed ) the LED blinkes slowly
When I programmed the PIC with the file ( CNCUSB_Bootloader-20100111_full ) the LED blinkes fast and the PC recognized a new hardware it is ( HID USB BOOTLOADER ) on the ( devices and printers )
On the PC the program icones are not active and I can not updated
Please I need your help and advice
Best regards
naser
Re: DIY did not recognized by the software
Postby Support » 16 Sep 2015, 13:07
Please update your controller with: Machine/Firmware/Update
If problem persists try different USB cable.
Postby naser » 17 Sep 2015, 06:46
unfortunatly the update didnt work
I changed the cable but nothing is happened ???
naser
Postby Support » 17 Sep 2015, 07:00
Postby naser » 17 Sep 2015, 08:30
Dear sir
The problem was in ( Cusb ) it was 100 pf , I replaced with 100 nf and every thing is ok
Many thanksfor you interest
naser
Postby Bakha » 10 Dec 2015, 07:41
AronKatler wrote:Can you please share all of your hardware details?
I want ti know about your DIY board?
Which PIC model you are using and what are the controllers and drivers on your board?
Also what are the specifications of the other components on your board?
http://www.planet-cnc.com/index.php?page=diy
Bakha
