Is it compatible with laser driver
Postby Yahya » 18 Jan 2015, 16:46
Hi
I am planning to biuld laser cutter with 100 watte power
And I have the diy pcb board so is it compatible to use pwm to controll the lader driver or it is only on /off controller
Yahya
Re: Is it compatible with laser driver
Postby Support » 19 Jan 2015, 08:30
Output pins for Mk1 controller support only On/Off control. PWM function of output pins is not supported.
Mk1 is our first controller. It is outdated and obsolete.
We really suggest that you take a look at our latest controller, especially the Mk3/4 controller:
http://www.planet-cnc.com/files/CNCUSBControllerMk34.pdf
All three output pins are able to generate PWM signal.
Postby knightlander » 25 Jun 2015, 02:06
I recently upgrade my cnc machine with a J Tech Photonics laser driver kit. I purchased the MK3/4 board so I could use PWM feature.
I have the driver board wired up to output #2 with PWM set at 2000Freq.
When I run the Gcode program the laser comes on but does not change. On the bottom of screen the spindle shows CW@0.
I am new to using PWM so I just want to make sure I have the software setup right?
I am using PIC Lite to generate my Gcode. I have attached the program to look at.
Thanks !
Laser Testing Instructions-BMP.txt
(742.79 KiB) Downloaded 148 times
knightlander
Postby Support » 29 Jun 2015, 07:18
Please also send your settings file.
Postby knightlander » 20 Sep 2016, 02:05
laser settings.setting
(50.98 KiB) Downloaded 35 times
Here are the setting I am using.
I am using Picengrave Pro 5 software to write the gcode for the pictures.
I cant seem seem to get the shading to look like some of these pictures.
http://www.picengrave.com/Pic%20Program ... Setups.pdf
Thanks for any help you can provide.
knightlander
Postby knightlander » 20 Sep 2016, 02:22
Here are the setting you requested. I am having problems getting the different shades of the picture. I am using Picengrave Pro 5 to generate the gcode.
Here is a link to a pdf of what the pictures should look like.
I am also attaching the program for you to look at.
Thank you for any help you can provide.
laser settings
(50.98 KiB) Downloaded 30 times
knightlander
Postby Support » 20 Sep 2016, 14:13
Ok, we will try to test this and we will get back with results.
Postby Support » 21 Sep 2016, 16:00
Unfortunately currently I found out our laser is not ready for work.
I suggest that you try different S values(also in settings), since the laser power might not be linear and you would need to test different S values in program.
try just testing S values from MDI and see what results are made on material
Return to DIY
