Help with diy pcb
Help with diy pcb
Postby Yahya » 31 Dec 2014, 11:56
Hello everybody
I have a problem with my diy pcb I would like to share
I make the copper pcb and connected the components good
And loaded the firmware on pic connected the usb 5 volt to the power
But nothing happen the led didn't blink and the o/p volte across the led leads is .8 volt
Is there any kind of test to check where is the problem
Whish nice new year
Yahya
Re: Help with diy pcb
Postby Support » 06 Jan 2015, 11:35
Sorry for such a late reply, we had a short holiday vacation.
Have you followed each step of assembly correctly?
Are all components used? Some users don't use pull-up resistor and that already causes problems.
Postby Yahya » 10 Jan 2015, 00:04
Thank you for the replay
In this period I try with my self and found the problem it was in the micro controller socket :D
Now I have anther question what is the purpose for the t b-bolck no 12
In diy page
http://www.planet-cnc.com/img/desc10small.jpg
I try to use it with or without wire the stepper still working and doesn't stop
Yahya
Postby Support » 12 Jan 2015, 13:48
This screw terminal has no use.
Postby Yahya » 13 Jan 2015, 18:51
So where is the emergency stop (hard stop)
Yahya
