Diy and licence
Diy and licence
Postby billy2sheds » 18 Jun 2014, 12:26
Hi I'm building my first usb controller
and I have it working on prototype board Close to the one in forum, and I'm about to commit to a final board.
in test (demo licence) I notice the board code and serial number has changed a few times due to updates in software.
So I take it I must have a finished board and working before I place an order for the licence.
Is this an option say I licence with working demo board, and use the pic-chip in final board, will licence be transfer to new board ok.
William
billy2sheds
Re: Diy and licence
Postby Support » 18 Jun 2014, 12:38
If you will use the same PIC microcontroller, then yes, license will be transferable.
Re: Diy and licence
Postby clementz » 13 Feb 2015, 22:47
I'm new to CNC, so I found your website on Google-search while searching for DIY USB CNC Controller Board. I have built the DIY Board found in the DIY section of your website and it was tested ok as described in the controller's manual.
Please I want you to enlighten me on how to get licence for my board to be able to have full control of my machine.
Activation Code: MUHJ-VDSN-RATH-IPVK
Serial: 054968
Also if I'm going to build more than one board, do I require separate license for each board? Because I'm planning to build "Laser Engraver" using the DIY board too.
Looking forward to hear from you
Regard
Clement
olaclemmy@gmail.com
clementz
Re: Diy and licence
Postby Support » 16 Feb 2015, 07:55
You can purchase license here:
http://www.planet-cnc.com/index.php?page=shop
Yes, each controller needs its own license.
Re: Diy and licence
Postby luiz s7 » 28 Aug 2015, 12:41
Good day,
am new here at Planet CNC,
developed a CNC plate equals Site DIY (http://www.planet-cnc.com/index.php?page=diy), as Silviu scheme.
I found that everything is working correctly, but with the limited software version of the 25 movements.
Question: If I adiquirir the license for this adapter DIY I'll get to work with the CNC with over 25 moves?
Grateful for the attention
luiz s7
Re: Diy and licence
Postby Support » 31 Aug 2015, 08:00
Yes, that is correct.
Re: Diy and licence
Postby luiz s7 » 31 Aug 2015, 14:17
Support wrote:Yes, that is correct.
Sorry, but I did not understand,
my cnc diy will have g-code Unlimited?
luiz s7
Re: Diy and licence
Postby Support » 01 Sep 2015, 07:15
Yes, after you activate your controller with license, your controller will be able to perform unlimited lines of g-code.
