Digital readout (DRO)
Which LCD color would you like most on DRO?
Yellow on black
26
36%
Green on black
29
40%
White on black
11
15%
Black on white
5
7%
Other
2
3%
Total votes : 73
Postby Andrej » 01 Feb 2012, 16:34
I've included only ones that are most visible.
Colors like light blue on blue are not visible enough in my opinion.
Prototype looks like this:
Re: Digital readout (DRO)
Postby dcasburn » 16 Feb 2012, 10:33
Is the digital readout part of the IC2 project, and are you going to produce these.
dcasburn
Postby Andrej » 16 Feb 2012, 10:58
Yes, I plan to produce them.
Postby matherp » 16 Feb 2012, 20:07
Techsupplies are selling excellent 20x4 OLED displays
http://www.techsupplies.co.uk/epages/St ... ts/AXE134Y
These are much easier to read than LCD
Best Regards
Peter
matherp
Postby dcasburn » 17 Feb 2012, 01:42
Would buying this I2C Serial 2004 module work ? and is this the same item similar to you I2C DIY device.
http://www.ebay.com.au/itm/I2C-Serial-2 ... 0700138365
I would like to add a coordinate system if possible.
dcasburn
Postby Moonglow » 17 Feb 2012, 04:21
OLED is good but it is really MUCH expensive! About 38$ ( inc VAT ) for this one... LCD looks good too... and have little power consumption unlike OLED.
Moonglow
Postby Andrej » 17 Feb 2012, 06:11
dcasburn wrote:Would buying this I2C Serial 2004 module work ? and is this the same item similar to you I2C DIY device.
This one will not work via I2C.
Postby skillalot » 27 Jul 2012, 14:31
Any updates on this LCD project?
skillalot
Postby Andrej » 28 Jul 2012, 21:02
Almost finished. I just need to improve some firmware things.
Postby cncnewbie » 14 Dec 2012, 20:08
Hi Andrej
Is DRO via I2C only accessible with MK2?
Cannot find info for connections and setup.
Settings/help file are only confusing and not very informative on this :(
cncnewbie
Postby Andrej » 14 Dec 2012, 22:43
I2C is on Mk1 and Mk2.
For Mk2/4 you need UART version. Plans are available here:
http://moonglow.zapto.org/?page_id=53
Postby cncnewbie » 15 Dec 2012, 06:51
So Mk2/4 supports DRO by serial only (TTL)?
Which pin is used for this?
Maybe it was a good idea to grey out functions that do not relate to model in settings :(
cncnewbie
Postby Andrej » 15 Dec 2012, 08:35
UART is on OUTPUT7 pin.
Postby TheHungry » 13 Jul 2013, 18:18
I have a question :
Can be increased refresh rate of the serial data channel ,because 10 hertz are a slow for more than 2 axes.
TheHungry
Postby Andrej » 13 Jul 2013, 18:27
Unfortunately this is not possible.
Postby TheHungry » 13 Jul 2013, 18:48
Could not be sent information about more than one axis on tick , I think it would not be delayed much the controller?
TheHungry
Postby Andrej » 13 Jul 2013, 20:14
There is too much delay.
Postby papymomo » 13 Feb 2014, 06:50
Hi Andrej,
is it allways possible to connect DRO on my new MK2 controller?
I suppose i must connect to I2C connection...
thanks for your response
papymomo
Postby Andrej » 13 Feb 2014, 09:46
It is best if you connect DRO to UART on OUTPUT7 pin. It is faster than I2C.
Postby papymomo » 13 Feb 2014, 10:43
Hi Andrej,
thanks for this quick response...
do you speak of output7 connecctor or connector limit 7& 8
I will see mor when I receive my MK2...
papymomo
Postby Wolffie » 18 Feb 2014, 02:41
Andrej wrote:I2C is on Mk1 and Mk2.
I am not very well versed with all the technical jargon and read only English.
I went on the suggested site but which one do I need for 2/4?
Which one is the UART?
Cheers
Wolffie
Wolffie
Postby Wolffie » 18 Feb 2014, 02:51
I guess the one I need is this one but, unfortunately, all I get is a diversion to another forum. I only read and write English :(
http://blog.fxdteam.com/?attachment_id=65
Cheers
Wolffie
Wolffie
Postby Andrej » 18 Feb 2014, 10:28
I'm sure Moonglow will be able to help you.
Postby Moonglow » 18 Feb 2014, 12:43
You can download project by clicking "external display for MK1, MK2 cnc controller" .. it is just wordpress do not made direct link by default and generate discution page :) btw you can use this direct LINK
p.s: you need also change source to support new MK2 protocol ( MK1 was not changed ), i will make it soon ( but i'm working on complete solution for now )
Moonglow
Postby Wolffie » 20 Feb 2014, 11:37
Thank you Andrej and Moonglow
:D Wolffie
Wolffie
Next
