Output board question
Postby Mharter » 31 Jul 2016, 23:48
Is the output board absolutely necessary to control the spindle on/off, fwd/rev and spindle speed for the mo 3/4 board or could I use a standard optoosolated 3 channel relay board as well? Just curious if that would be possible. Or even a 2 channel relay as lines only come from 2 of the channels on the output board to the VFD, if I am reading the wiring diagram correctly.
Mharter
Re: Output board question
Postby Support » 01 Aug 2016, 10:28
Of course it is not absolutely necessary. You can use your own board with relays or SSR.
Make sure that you convert freq. signal from controller to 0-10V signal if you will use analogue voltage for spindle RPM control.
Postby Mharter » 01 Aug 2016, 10:40
How do you convert the frequency signal? Is that in the VFD? PD070.
I wired up a two channel relay last night. Got the spindle to turn on but couldn't get it to initiate spin. I must need to figure out a way to tune the voltage. Any help with that would be greatly appreciated.
Mharter
