Show your machine
Show your machine
Postby skillalot » 11 Jan 2012, 20:11
Hi to all,
as a first post on this forum, let's start with introducing our machines to eachother. I'm very curious to see the machines other people made, and control with cnc-usb. So please post 1 or 2 pictures and tell about it. How did you make it, what are the dimensions, etc.
I will edit this post tomorrow and add some pictures and tell something about my machine.
EDIT: a bit (2 months) later, but my machine is here aswell... scroll down.
skillalot
O.K. I show you mine, you show me yours'
Postby JerryBurks » 14 Jan 2012, 05:19
I am 95% finished and the machine is operative (build started last August):
- Moving gantry router with a range of 36" x 32" x 8"
- Structure built from highly rigid bamboo plywood
- Linear ball bearings 20mm from Glacern.com
- NEMA34 steppers with 15mm precision Kuroda ballscrews, Gecko 203V drives
- Table is 80/20 brand aluminum extrusion on a bamboo plywood box, mounted on a cart
- Chinese high frequency spindle (first 1.5kW, now 2.2kW with Hitachi VFD)
- No cost figure, I stopped counting at some point......
Ha! I notice you can not post picture here. Oh well here are the links to some pictures:
Admin: Please post images as attachments!
JerryBurks
Re: Show your machine
Postby sblacklord » 26 Jan 2012, 02:02
Hi your machine looks great! :mrgreen: Sorry I am still in the Process of gathering bits and pieces so I have nothing to show yow you.
Shane
sblacklord
Postby Kristof » 26 Jan 2012, 15:29
For now I have only these two pictures. Taken with cell phone. But I will make more pictures of the controller box , touchscreen computer and machine. This time I will use regular camera :mrgreen:
I convert the machine from manual to CNC. Original machine is LittleMachineShop Hi-Torque Mini Mill. I bought the CNC convert kit from CNCFusion and controller board, step motor controller and step motors from Probotix.
1
2
Kristof
Postby grawsom » 27 Jan 2012, 10:07
Just great that there is a fora to get help :D
I'm new to CNC, but you have to start somewhere, found an old machine that have been used for education in a school, the guy I bought it from was going dead in the electronic...
I'm now going to start of with Andrej's controller and some other stuff from him - seems that the software is more strait forward.
Picture of my machine:
Picture of the old controller:
Future plans::
Webcam, 7"/10" touchscreen, external keyboard panel..for quick functions..
Just can't wait to get this up and running.
Do a lot of simracing and build some add-ons for wheel, so is hoping to make some fancy stuff in the future.
grawsom
Postby saiyan » 01 Feb 2012, 20:02
Hi guys,
This my diy micro Gantry CNC 3 axis (3020 inspirat)
MK1 with Diy Drivers (old Probotix)Work at 3000 speed travel, homming, Z palpeur,Jog, diy spindle Brushless 25000 trs/min & Led light, no problems for work aluminium
Cheers
Photo 009.jpg (89.59 KiB) Viewed 10579 times
saiyan
Re: O.K. I show you mine, you show me yours'
Postby fystudio » 07 Feb 2012, 12:28
I like your artwork, what milling cutter do your use?
fystudio
Postby Kristof » 07 Feb 2012, 13:43
What thickness of aluminum you can mill? I thought about getting one of these but everybody told me that on milling aluminum this machine will not perform too good because the motor is to weak
Kristof
Postby saiyan » 07 Feb 2012, 16:13
I Use For milling aluminium sheet 1mm- 1.5mm- 2mm & 5mm
end mill 1-flute or end mill 2-flute, it's good result with advance 500/min ~ 10 000 trs/minutes spindle
and multi pass depht ( 0.3) & milling in "Avalant" Mode ( sorry in french!)
I don't use the original spindle ( type E240) use for this : Brushless Spindle HomeMade by Me ;)
I post new pictures asap because now i modify the table machine for big good result !
Regards
saiyan
Postby wilfred1970 » 20 Feb 2012, 18:44
@saiyan: Can you tell/show more about your homemade brushless spindle? I am very curious about that.. :shock:
wilfred1970
Postby Kristof » 12 Mar 2012, 10:05
Here you go guys some pictures. I know you love pictures :D
Kristof
Postby TCWORLD » 14 Mar 2012, 21:32
@JerryBurks I really like the pattern you milled on that piece of wood :)!! Would you be able to share the G-Code file? I'd like to try and make a smaller version :D
TCWORLD
Postby JerryBurks » 17 Mar 2012, 01:57
Double post, deleted...
JerryBurks
Postby JerryBurks » 17 Mar 2012, 02:04
TCWORLD wrote:@JerryBurks I really like the pattern you milled on that piece of wood :)!! Would you be able to share the G-Code file? I'd like to try and make a smaller version :D
Yes I can but at 3MB it is too long to post it here. Instead you can try to download it from my Public Dropbox.
I will leave it there for a few weeks and then delete it.
Obviously you would have to scale it somehow to your blank. I used a 90-degree V-bit at 15000 rpm to cut in an old maple shelf board. To get a clean cut of the intricate tiny squares you need to experiment with you starting depth. Too little and you don't see the detail, too much and it just makes a fat groove. And you REALLY need a sharp bit.
Executing the code, an earlier version of the planet-CNC software got stuck due to USB buffer overrun (if i remember correctly) but I could resume with no problem. But that was in the old times, some 200 versions ago :mrgreen:
Admin: I zipped and attached this g-code
CheckerboardFractal.zip
(726.68 KiB) Downloaded 305 times
JerryBurks
Postby TCWORLD » 17 Mar 2012, 15:13
Thanks very much, I will experiment and see what I can make :D.
Tom.
TCWORLD
Postby skillalot » 26 Mar 2012, 19:49
Oke, it's been a little longer than 2 days to post pics of my machine, in fact it's more like 2 months, but here goes:
My machine has a working enveloppe of 1020x520x150mm. The base of the machine is made from 60x60x5mm steel square tube. It uses 16mm supported linear roundbars, and 16x5 ballscrews. Nema 34 steppermotors with 3Nm torque, 48volt power supply and the MK2/9 controller.
Still not finished, I'm still working on end / homing switches and need to mount the cable chain. And I still want a toolsensor, 4th axis, aluminum T-slot table instead of the poor MDF. And I want to make a box underneath the bed with mounts on it to place screens in, so that I can mill aluminum with a flood cooling.
Here are some pics.
Design of the baseframe and bridge. Drawn in Alibre Design. Made from 60x60x5mm square steel tube.
Design of the bridge. Made from 15mm aluminum sheet.
One part of the baseframe, 1200x240x60, welded with oversize, cnc milled to be square, flat, and the right size. One side isn't milled all the way, but left 10mm to have a small edge to support the linear guides. Makes it easier to mount them parrallel with the frame.
Both base parts connected to big angle irons. My machine is at the attic, and it had to be made into pieces to get it up there. It's very heavy...
Here is the base of the machine complete. The frames on the sides are welded, and bolted underneath the angle iron. The long tubes in between are bolted.
I couldn't find a cabinet for the electronics, that suited my needs. So I designed one myself. I asked a company to lasercut and bend it, and TIG welded it myself.
Here is the cabinet completed and mounted to the machine. The panel is changed now, and will change again soon to get a start, stop, pause and maybe more buttons (keyboard shortcuts).
All the parts for the electronics. Look at the wooden bridge. While designing on the computer should be sufficient, it's always good to try things out for real first. You'll see lots of things you hadn't thought about before on drawing.
skillalot
Postby skillalot » 26 Mar 2012, 19:54
maximum of 8 attachements reached, here is the rest of the pictures.
The electronics cabinet. The area above the MK2 board on the left, empty here, now got a earth rail. All cables with shielding goes over that rail, above the rail the isolation is removed around 15mm, and the cables are strapped to the rail. All shieldings are together at one point, minimizing EMC. The PVC on the right is my watertank for the spindle cooling, there is a small 12v pump inside. The psu above is 48volts for the steppers.
Here is the watercooled spindle. It's 1.5Kw and got a ER11 collet. Maximum size collet normally is 7mm, but there are oversizes for 7.5 and 8mm.
And here is the complete machine.
skillalot
Re: Posting images
Postby feuerring » 23 May 2012, 18:49
This Pictures are from my CNC
Control-BOX with MK1 and Isolation-Interface
wiring diagram from the Isolation-Interface
feuerring
Postby feuerring » 23 May 2012, 19:15
Hello
I would also like to introduce my machine times.
It was built this aluminum, three parts, I had my mill from a friend.
The machine is still under construction, but can already be moved over the MK1.
Here are some pictures:
feuerring
Postby jettanakorn » 08 Oct 2012, 09:30
Hi!
My machine name ALPHA 7, Main structure is AL6061T6 with blue anodized and laser marked finishing. This machine is under construction.
Design for making composite mold.
JFOX CNC-79.png (81.92 KiB) Viewed 9102 times
Some design picture
JFOX CNC-77.png (187.54 KiB) Viewed 9102 times
Some parts made from machine shop of my friend.
Z Axis
jettanakorn
Postby mwthetm » 13 Mar 2013, 00:34
My DIY CNC Router
5th generation CNC build.
I finally got it right.
Double 3/4" Plywood frame.
Igus Double rail with dryline bearings.
Roton Hi-Lead - Lead screw.
Probotix yellow motor kit
Will run over 200 IPM
Didn't have a need to test it any further, I'm cutting wood.
Will cut at 50 to 60 IPM all day. Yes I run it all day.
Had it in a small room but tore it down and building another, lighter and quieter.
WP_000271 SM.jpg (93.91 KiB) Viewed 8246 times
mwthetm
Postby Teelzebub » 27 Mar 2015, 12:10
Some pictures of the beast :twisted: I originally had a Shapoko2 which was fun but wasn't up to cutting aluminium so after many upgrades and still couldn't do what I wanted it just wasn't rigid enough I decided heavy steel construction was the only way to go now weighs in at 140kg :shock: anyway with some help from Zap Automation where I bought all the parts this is how it turned out.
CNC 002 - Copy.JPG (224.09 KiB) Viewed 4208 times
CNC 001 - Copy.JPG (207.56 KiB) Viewed 4208 times
Teelzebub
Postby plan123 » 09 Mar 2016, 23:49
this is my first post on the forum so i decided to start with presentation of my machine.
Motors: Leadshine easy servo motor nema 32 (8nm torque)
Drivers: Leadshine easy servo DB-808
Spindle: Mototechnica sb c41/47 2kw (with water cooled modification)
Ballscrews: Gten 25mm/5mm C5 quality
Ballnut: Gten duble preloaded nut (0 Backslash)
Controller: Cnc-usb MK3
Power supply: 2x 500W
PC: An old core2duo version
Photos:
plan123
Postby Support » 10 Mar 2016, 07:45
Looks great!
Postby mwthetm » 14 Jan 2017, 15:27
I'll enter this.
I've built 8 machines using CNCUSB Controllers. Recently migrated to the MK3 from the MK1.
To be honest The software and hardware is amazing. The MK1 is still good.
This set-up is my latest build. I used materials from several places. The rails from a site that sells V Groove Rails. Aluminum plate from a local supplier.
This time I'm using belt drive I picked up on Amazon.
Machine cuts 23X32 and is perfect for doing a lot of projects.
In setting up this new build I ramped it up to 500 in a min but couldn't get that fast due to the size of the machine. I ran a simulated project with a lot of changing directions at over 200 in a min and it was solid.
I would never be able to cut at 200 in, I'd snap bits. Many times I use routerbits as small as .015.
mwthetm
