Plurato CNC milling machine
Postby Niksa_cnc » 17 Jan 2016, 11:07
Hello everybody, I want to present you my the very first CNC project so I will upload a few pictures of manufacturing and testing my CNC.
At the beginning I got a parts like stepper motors, drivers, spindle, linear rails, balls crews etc... and a task to design a machine for PCB milling with capabilities to do some basic 3 axis aluminium, wood or plastic milling.
So I did some internet research and CAD modelling of components to fit them to a housing from 15 mm AlMg3 panel.
While project was developing, I did some iterations in design and find new solutions for problems.
Niksa_cnc
Re: Plurato CNC milling machine
Postby Support » 20 Jan 2016, 08:53
Nice design, how(with what kind of machine) will you will the frame parts?
Postby Niksa_cnc » 20 Jan 2016, 16:15
Support wrote:Nice design, how(with what kind of machine) will you will the frame parts?
I milled frame parts on this Chinese machine.
Niksa_cnc
Postby Niksa_cnc » 20 Jan 2016, 17:06
Manufacturing and assembling frame parts.
Niksa_cnc
Postby Niksa_cnc » 20 Jan 2016, 17:18
Manufacturing and assembling frame parts vol. 2.
Niksa_cnc
Postby Niksa_cnc » 20 Jan 2016, 17:21
Manufacturing and assembling frame parts vol. 3.
Niksa_cnc
Postby Support » 21 Jan 2016, 09:05
Nice. When you start it you can post a video of machining.
Postby Niksa_cnc » 22 Jan 2016, 09:58
Support wrote:Nice. When you start it you can post a video of machining.
I started it and did first tests these days. I have a lot of work on it to enable more features supported by controller and I have to do a fine tuning of machine mechanics.
I will add a encoder for controlling spindle, tool offset switch, movable tool sensor and camera.
Here is the testing preview.
https://www.youtube.com/watch?v=U99GVRh3lkk
Niksa_cnc
Postby Niksa_cnc » 22 Jan 2016, 10:12
Wiring and testing.
Niksa_cnc
Postby Niksa_cnc » 22 Jan 2016, 10:25
Wiring and testing vol.2.
Niksa_cnc
Postby Niksa_cnc » 05 Mar 2016, 08:14
I have made a tool-free clamping.
Niksa_cnc
Postby Niksa_cnc » 16 Mar 2016, 18:16
Some new parts for a machine...
As you can see, I decided to use PC as housing for all electronic parts so as result I have "all in one" configuration.
Tool offset sensor
Emergency switch
Niksa_cnc
Postby Niksa_cnc » 16 Mar 2016, 19:27
Finishing PC housing..
CNC made this part for itself :-)
Niksa_cnc
Postby Niksa_cnc » 16 Mar 2016, 19:33
I made some PCB parts for quadrocopter of my colleague and I am pretty satisfied with accuracy..
Niksa_cnc
Postby Support » 17 Mar 2016, 12:22
we would recommend that you use shielded cables for your wiring. EMI can cause big problems with communication.
