Maze Cam software
Maze Cam software
Postby JerryBurks » 04 Jan 2015, 00:15
I have been working on and off on software that can generate mazes and the required g-code to cut. I finally finished a beta version and a manual and hope somebody will try this and give me feedback. Not sure if I posted earlier results here but I thought somebody might like it.
https://dl.dropboxusercontent.com/u/29562014/MazeMakerInstall.zip
Simple one-sided maze
Cylindrical maze (with indexer)
Double-sided maze in front of a mirror
Large maze 3x24" with keepout pattern, single sided.
JerryBurks
Re: Maze Cam software
Postby hungryarie » 13 Jan 2015, 19:58
Wow! that looks awesome Jerry!
I want to give the software a try, but my firewall keeps sandboxing the programm :|
hungryarie
Postby JerryBurks » 14 Jan 2015, 20:45
hungryarie wrote:Wow! that looks awesome Jerry!
I know that is a problem with some antivirus and firewall software. I am using LBB to create the executable and some heuristic analyzers see that as potential threat. I had a conflict on my own machine with Panda Antivirus and needed to give special permission to run the development tools as well as the executables. Sometimes it seems to be sufficient if you run it as administrator once.
Sorry about that but I am not sure if there is a simple fix.
JerryBurks
Postby hungryarie » 19 Jan 2015, 13:50
Thanks. I will try running it as admin.
hungryarie
Postby smartroad » 01 Feb 2015, 20:26
Nice! What type of cutter have you used?
smartroad
Postby JerryBurks » 07 Feb 2015, 22:18
smartroad wrote:Nice! What type of cutter have you used?
It is a simple end mill for slotting and removing most of the material and then a ball end plunge router bit to make the undercut. You can get them e.g. from Magnate in 3/8", 1/2" or 5/8" ball diameter with 1/4" shank.
JerryBurks
Postby Superoo » 19 Apr 2015, 03:51
Nice Jerry,
What is the license purchase procedure ?
cheers,
Superoo
Maze Cam software
Postby Frizythul30 » 13 Mar 2016, 05:53
I have tried it using the profiles that cames with the software and it "stalls" when you try to mesh
Frizythul30
