Brushless spindle
Brushless spindle
Postby saiyan » 22 Feb 2012, 07:56
Broche .png (15.42 KiB) Viewed 5220 times
Hi wilfred,
I have made concept spindle Brusless with motor brusless kv800 ( ebay)
i have coupled with er11 collet & flexible coupling
24V power supply é drive with servo tester for speed control
saiyan
Re: Show your machine
Postby wilfred1970 » 22 Feb 2012, 19:04
I've been looking for these motors on Ebay; how powerful is it? What kind of materials can you handle with this r/c motor and how deep/thickness?
it makes me curious ... :geek:
wilfred1970
Postby skillalot » 25 Feb 2012, 20:51
wilfred1970 wrote:it makes me curious ... :geek:
Me too,
do you have any pictures of the build process of it? What bearing do you use in it, what collet chuck and where did you bought it, etc?
Regs,
Sascha
skillalot
Postby Bakha » 26 Feb 2012, 08:13
Bakha
Re: Brushless spindle
Postby Andrej » 26 Feb 2012, 13:56
Did you know that controller can generate "RC controller" compatible signal for spindle speed?
You can use it to control RC servo motors or ESC for brushless motor.
No need for servo tester :-)
Postby Bakha » 26 Feb 2012, 15:52
Yes, I'm using.
Bakha
Postby orangelive » 08 Apr 2012, 17:12
Hello
Here is my brushless spindle from a 18-year-old Proxxon drill.
I use a brushless motor 2827-34. Previously I had installed a Maxon motor instead of the BL with 20 watts. Now the spindle has more power and runs quieter. The controller is a selbstau of Mikrokopter.de. At about 10 volts, a current flows from 1 to 1.5 A. At the moment I still use a servo tester on the MK1.
Jürgen mfg
orangelive
Postby orangelive » 13 Apr 2012, 19:27
And now created with the help of the Proxxon this version, small and compact (40x30x50).
This time a BL motor 2824-34:
Load current: 4-8 A
Load current. (60 sec): 9 A
Idle speed: 1100 rpm / V
Wave power: 90 W
Dimensions: 28.8 x 26 mm
Shaft Diameter: 3.17mm
mfg Jürgen
orangelive
Postby wilfred1970 » 05 Jun 2012, 20:29
Looks really great guys!
I'm quite inspired by your posts.
Soon I'll be posting too....
wilfred1970
Postby Kostadin » 25 Jul 2017, 17:36
Andrej wrote:Did you know that controller can generate "RC controller" compatible signal for spindle speed?
How to connect. How to setting shpindle in shpindle menu in DIY controller.
Kostadin
Postby Support » 31 Jul 2017, 14:33
