Where to buy mills etc.
Postby grawsom » 06 Feb 2012, 10:36
Now it's allmost time to get some milling done, but only have a small one for graving...
Are there anyone who could recommend a place in EU, maybe a beginer set...
grawsom
Re: Where to buy mills etc.
Postby m_thread » 06 Feb 2012, 12:58
Hi if it is end mills you mean (milling bits), (pinnfräs på svenska) you could buy them from sorotech.de, or cnc-plus.de. Since you live in Denmark the shipping will probably be quite fast and cheap.
Edit: It should be sorotec.de
/F
m_thread
Postby grawsom » 09 Feb 2012, 07:30
Thank's Fredrik
I will take a look at these sites...
grawsom
Postby grawsom » 14 Feb 2012, 12:29
What are the most common used tools for CNC - have to start from scratch with tools...
grawsom
Postby Andrej » 14 Feb 2012, 12:43
I mostly use:
EndMill 2mm
EndMill 3mm
EndMill 6mm
EndMill 8mm
BallNose 1.5mm
BallNose 3mm
V-bit 36deg, 0.2mm
I'm also interested what others use.
Postby matherp » 15 Feb 2012, 10:44
I'm doing mostly aluminium work (upto 12mm thick). I use single flute cutters like Onsurd 3/16 x 5/8 SE UC Spiral o' flute cutter which I buy online from cutter-shop.com who have a large selection
Best regards
Peter
matherp
Postby Kristof » 29 Feb 2012, 11:39
What is the best tool to cut a slot in 3/8" thk aluminum?
Kristof
Postby alexbailey » 04 Jun 2012, 10:48
Ai-TEC - your leading source of cnc milling. It allows you to manufacture precision-machined components using turning and milling machinery.
alexbailey
