CNC Enclosure - DIY Guerrilla style.
Postby Markp » 22 Jan 2015, 18:32
Has anyone ever cannibalized a dishwasher as a CNC enclosure... It just seems like low hanging fruit for my DIY CNC Mini Mill.
Thoughts?
Markp
Re: CNC Enclosure - DIY Guerrilla style.
Postby m_thread » 23 Jan 2015, 12:06
Sounds like a really cool idea. There is sound insulation from the beginning and it is air/watertight also. There is even a cooler fluid pump with some minor mods. What would be needed is a glass front to enable you to see whats going on inside though :) Or maybe a webcam could work as well?
Go for it!
/F
m_thread
Postby Markp » 17 Mar 2015, 07:26
After all the retrofitting of CNC components, it's a bit small, but I have not given up. I think that I will use just the base and build the enclosure around that... I had hoped to use the door with Acrylic to allow a view inside, but I suspect that it will require me to loose the frame potentially.
The CNC goodies are running, now for the work of making the enclosure.
Markp
Postby Support » 17 Mar 2015, 09:29
You should definitely post some pictures :)
Postby DerFarm » 24 May 2015, 01:12
What if you used a large wall oven? They already have glass doors, soundproofing, heat proofing and most have a light already installed. They even have an available huge power source.
DerFarm
