Loose Axis Nut
Loose Axis Nut
Postby Moonwalker » 09 Dec 2014, 11:53
I was cleaning my CNC and noticed that the X-axis nut has too much play. I think it needs replacement. This nut seems made of nylon or plastic.
So should I contact the manufacturer and get a replacement or maybe I can replace it with something better?
See video in this link - http://1drv.ms/12mohW7
Moonwalker
Re: Loose Axis Nut
Postby Support » 10 Dec 2014, 08:42
Getting the original part from manufacturer would probably be the best solution.
Or you could replace the complete lead screw with nut. But this is more complex task i guess.
