Rapid tool change(er).What approach is better/cheaper?
Postby lapilesos » 15 May 2014, 11:48
a using more then one tool wiht ER-20 s slow and somehow unfun :). I know there exist are some Toolchanger but most of them require pressed air and have costs above 1000 euro. At the same time i saw on youtube some machanical changers with pretty simple construction and reasonable price (http://www.youtube.com/watch?gl=DE&hl=de&v=M9rN96r1c6I as example) Anyone knows some actual systems for applying on ER-20?
Is dosn't matter much if this is manual or from magazin like on video. It should be just quick, with good runout and most important under 500 Euro pricetag.
What i found until this time :
http://www.royalprod.com/product.cfm?catID=11 - R8 and pretty expensive
http://www.hightechsystemsllc.com/rapid_changer.html - EOL and allowed only upto 10000 RPM (AFAIK its same you saw on youtube video)
Thank you in advance.
lapilesos
Re: Rapid tool change(er).What approach is better/cheaper?
Postby lapilesos » 26 May 2014, 13:12
Hi again,
looks like everyone do changing tool manual or using pneumatic ATC?
Seems like it is inevitable to take an ATC fro China Spindel ( I have 2.2kW ER-20 one) :(
WBR,
Andrew
lapilesos
Postby lapilesos » 06 Jun 2014, 08:40
Bad news for 2.2kw China Spindle owners - there no ATC for ER20 collet. Only for ER11 ( usovo.de ).
Just wounder if there any adapter ER20 to SK20? Or its pointless due mechanical problems with such construction?
WBR,
Andrew
lapilesos
Postby Andyfromchina » 17 Nov 2014, 04:10
i may can help
Andyfromchina
