Fixed vs Movable tool size sensor
Postby evgeninikolov » 11 Sep 2013, 06:33
Well, the subject says it all - does one need both? What are the benefits of each?
Can you recommend a cheap and good one?
Can I use PCB for fixed?
Are any other options for movable apart from PCB and are they better than PCB?
Regards,
Evgeni
evgeninikolov
Re: Fixed vs Movable tool size sensor
Postby Andrej » 11 Sep 2013, 08:59
I suggest you use moveable for measuring material top turface (offset Z) and fixed for measuring tool offset.
There are a lot of options what you can use. PCB is one of them.
Postby evgeninikolov » 11 Sep 2013, 09:11
Can I use the moveable for for both? Or is there a big disadvantage apart from needing to move it always?
evgeninikolov
Postby Andrej » 11 Sep 2013, 10:48
Moveable does not have known position. You can use it to measure "one thing" such as material top surface. But if you change tools you need to measure "two things". Difference between tool1 and tool 2 is needed ond for this you need known reference. Fixed sensor is at known position and can be used as reference.
Postby evgeninikolov » 11 Sep 2013, 11:06
Yes, but the movable could be placed to a known position, isn't it?
evgeninikolov
Postby Andrej » 11 Sep 2013, 21:21
Yes, but if it is at know position it is no longer movable. It is at known position therefore it is fixed.
Postby lapilesos » 28 Oct 2013, 09:21
So, basically it is neccecity to have both of them?
lapilesos
Postby Andrej » 28 Oct 2013, 16:08
It is not necessary.
On my BF46 I usally don't use sensors at all. On big router I use both of them.
